Ackbar00
- Jan 18, 2021
- Dayton, Ohio
- Paul
- 2020 Mustang GT / 1969 Mustang 302
So after YEARS of trouble free service, I made the decision to screw everything up, and put a supercharger on my car! I latterly wrestled with this idea for over 2 years. Was pretty hung up over doing a 6-71 for awhile, but I couldn’t justify the price and what it would have taken to get working on my car and combo. The TS was litterly half the price. So here is the current NA combo:
1969 Mustang Coupe
Stock 1990 Mustang 302
Edelbrock Heads and intake
FMS "B" Cam
MSD Dizzy and 6AL Ignition
Holley 650
Carter M60454 Mechanical Fuel Pump
Flowtech headers
T5 setup
Since I have already converted to a Fox Serpentine setup, I went with kit part number: ARP-K-FD-302S
https://torqstorm.com/product/kits_single_small-block-ford/
Fuel System will be:
After 6 weeks, the box shows up. Decisions decisions on which Mustang…
Last look of the NA setup.
Removed all the stock brackets out of the way.
Test Fitting the TS mounting bracket
So here is my first complaint. The instructions are very simple, like 6 steps. My issue is I get a bag of hardware, a lot of idler pullies and no idea past some pics on the internet on what goes where. Even when you get a 40$ desk from IKEA, it has all its hardware in individual bags! This really took me a minute to figure out. Had to separate all the hardware out on my tool bench and start labeling everything as I found out where it went. My kit came with a fair amount of spare hardware, which is nice if you need a replacement for something, but it’s really not labeled as such.
So finally got things were they needed to go
And that is about all I made it to the first day or so. Have a pretty fair amount of work ahead of me. Some things I know for sure I would need to change.
The carb hat and couplers. Their kit has it coming over the distributor and I know it would not fit. Pretty sure I can get some different couplers and run it differently.
Upper rad hose
Wiring…. All of my wiring is in the way. When I built the motor years ago, the battery was moved to the trunk and I placed my 6AL and everything else right there. Its all pretty much in the way and will need to be moved in some capacity.
1969 Mustang Coupe
FMS "B" Cam
Holley 650
Flowtech headers
T5 setup
- Aeromotive Stealth tank 18147.
- Redhorse Performace Pushlock stuff f for feed
- Stock 3/8 line for return
- Aeromotive 13301 Regulator
- APD Blowthrough Carb
Upper rad hose
