Torco & Procharger
SolarFlare
S. Fla
2015 CO GT
Dang right. :)
That intercooler we made for these cars is the BOMBDOTCOM!
No doubt. I wanted no issues with IATs in south Florida, considering track techs love to make you sit in the staging lanes for 30+minutes
dubster99
Nor*Cal
2015 Ingot Silver GT PP
I prefer torco, but for $13.24 that's cheap as f.
Crackerjack17
WV/Maryland
2017 GT PP
What's your total timing?
The one thing I love about this Procharger is that the thing appears to have 0 issues with IATs. I can drive this thing for 1 hour and still see 2-3 degrees above ambient. Amazing!
at the almost -6 knockr, its showing saftot - 29.5? that's in 4th gear, wot. a/f is 0.85
when I go wot saftot is at 22 around 3800 rpm then increases to 29.8 at 6150
SolarFlare
S. Fla
2015 CO GT
30* of timing?? Thats a mistake. And Lambda at 0.85 on boost sounds way lean. Sure youre looking at your boost logs and not your NA logs?:confused:
Tommy V
Brookly park Md
Tommy
:eyebulge:Yea that definitely dont sound right for boost,30 degrees of timing:eyebulge:
Crackerjack17
WV/Maryland
2017 GT PP
Well crap, maybe I am looking at wrong one. I data logged and that thing makes all the files same date. I'll clear the card and do it again. I have two ngauges. I see a/f live on ngauge when I'm wot and it usually 11.8-12.2
Im working on hooking up fuel and boost gauges.
And ever since I installed the supercharger my exhaust tips are black as hell, so should be running rich?
Crackerjack17
WV/Maryland
2017 GT PP
ok, I'm officially an idiot. I was looking at wrong file. So, I made a pull about 30 minutes ago, up a pretty decent hill on the highway. Started at 4000rpm in 4th and wound it out through 4th and 5th.
Looks like 20-21 total timing. lambda 0.80 - 0.82
Tommy V
Brookly park Md
Tommy
Now that sounds right on the money
dubster99
Nor*Cal
ok, I'm officially and idiot. I was looking at wrong file. So I made a pull about 30 minutes ago, up a pretty decent hill the on highway. started at 4000rpm in 4th and wound it out through 4th and 5th.
So you're running one can in a full tank of what? 93? That timing still seems pretty high to me, but not crazy. What timing were you seeing before you added the octanium?
dubster99
Nor*Cal
Im seeing .77-.78. 20-21* is solid if tuner thinks its ok. Maybe the octanium bumped it up a bit.
That is with octanium? My lambdas are also in the .77-.79 range, but my timing is way low due to our shitty 91 we get here. .82 is on the high side for boost.
SolarFlare
S. Fla
2015 CO GT
No, I'm seeing that lambda and ~18* timing (sometimes as high as 20*) on straight 93. I would be very happy if I see a steady 20 when I put in torco.
dubster99
Nor*Cal
That's some pretty solid 93. I'm sure this winter blend of 91 isn't helping anything, but even our summer 91 sucks.
Crackerjack17
WV/Maryland
2017 GT PP
Sunoco 93. Yes, one can of octanium in full tank. I don't know what the timing was before the octanium. I was seeing +knockr so I added it. I just finished installing this kit not long ago. It's on the stock procharger tune for the moment.
