Top trouble
Smitty50
Minnesota
2021 mustang convertible
Hi guys, I have a 2021 mustang convertible and when putting the top up it stops about two inches from the windshield frame and won’t go any farther. Any help would be appreciated.
KeyLime
Pleasanton, CA
Lenny
2021 GT/CS Convertible
My top (2021) needs to be pulled down an inch, maybe a half inch to get the latch to engage. Cold days make it worse. My old 85 with a vinyl roof was a nightmare in cold weather. It just wouldn't stretch out. On occasion I'd have to let it sit in the sun for a bit to get it closed.
I don't have a lot of experience with the fabric roofs, but I see you're in Minnesota. If it's really cold that may be the problem. Perhaps the dealer can make an adjustment to help out a bit.
Avispa
Oldsmar, FL
Richard
2016 Mustang GT/CS convertible
It's normal.
Yes, it sure is. As long as you can pull it closed to operate the latch, you're good. Believe me, it used to be a lot worse with vinyl convertible tops.
Johnnybee
Canada
2018 convertible
As above, you have to pull the top the final inch or so to engage the latches.
jtmat
DC/MD/VA metro
Vert turbo!!!!
That never happened with my 2015... and I'd drop the top anytime it was not raining and between 60 and 90 degrees. I would get it checked out like kingstone suggested.
Jackismydog
L'Islet,Qc Canada
Francois
Mustang GT 2016 Convertible
2 inches normal ? not for me!!! 2021... don't hesitate run to see your dealer. This car is still under waranty. My 2016 completly sit where is it supposed to and I used it many times. Do have to use my hand to close the gap.
#1ford
#1ford
Joe
2021 mustang gt premium convertble antimatter blue
It should be under warranty,that’s a good thing.👌
White Stallion 11
RJ
'15 EB Prem Vert w/PP, '20 GT Prem Vert w/PP
I bought a 2015 new and have not experienced what has been discussed thus far--no gap whatsoever upon running it up.
As said, being that you are under warranty, take it back to the dealer for evaluation.
R.J.
