Tire question
FUN2RIDEFAST
Ofallon, Missouri
2017 Mustang GT Premium/PP
I installed a Roush Phase 2 supercharger in November and when the weather gets better I'm going to run Nitto 555r2 305/35 /19 tires on the rear. My car is a PP and my question is should I run the 245's on the front or the 275's?I'm more interested in function over looks. Does either way make a difference? Thanks in advance for your help.
DaveR.PP2
Connecticut
20 Mustang GT PP2 ; 67 Shelby GT350; 67 Mustang S Code Coupe; 88 Mustang LX 5.0 Coupe
I tend to prefer one size differential between front and rear if you stagger. Two size differential tend not to be a good thing unless you're running a street rod or something like that. My opinion.
Crowd Hunter
Tennessee
$hitbox
What is "one size differential" and "two size differential"?
FUN2RIDEFAST
FUN2RIDEFAST
Ofallon, Missouri
Thanks for the info.
Vert
Indiana
Whipped 19 GT Premium
I was running 285s up front and 305 G2s and this year since I bought more rims, I'll be running 275s in front and 305s riis in the rear. To me, the 285s looked too big in the front.
FUN2RIDEFAST
FUN2RIDEFAST
Ofallon, Missouri
Sounds like a plan. I'm going to do the same. Thanks for the information.
m3incorp
Georgia/Colorado
James
I run 275/35 fronts and 305/35 rears on both sets of wheels.
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
On the PP wheels? I wouldn't go any bigger than 285 on the 9.5 inch rear PP wheels. Get a set with 11 inch rear wheels if you want the benefit of the wider tires.
m3incorp
Georgia/Colorado
James
I drove it home on stock and changed them out as soon as I pulled into the garage. Also, mine are 20s I am sure they ride just a tad bit stiffer than stock.
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
What wheels?
Dave2013M3
El Segundo,Ca
This
FUN2RIDEFAST
FUN2RIDEFAST
Ofallon, Missouri
I've got a PP car. I'll put the rears on the front and I already have a pair of eleven inch rims for the Nitto's. Thanks for the reply.
DaveR.PP2
Connecticut
By that it means to evaluate a given manufacturer's production sizes identifying tire section width, aspect ratio and wheel diameter... for any given tire application I'm considering just one of the things I do is to know the ranges of sizes available if I am going to use staggered sizes on any vehicle I run. I might in this example run a 315/30ZR19 on the rear and a 305/30ZR19 fronts...this example in the Michelin Pilot 4S is one size differential.
Many times you'll find limitations in consecutive sizing ranges and It's because of OEM manufactured reasons and/or supply and demand for certain types of tires.
So it's all about minimizing the variance in tire dimensions between front and rear tires assuming the same product set of a given manufacturer's. This reduces problems with overall handling problems and keeps the overall tire dimensions within a range that doesn't compromise safety.
A good exception in tire size differential is what you see on a top fuel dragster. But then that's an entirely different application of course!
kluke15
Reno, NV
Kenny
2017 Mustang GTPP
i had 285 on the front and would tramline everywhere. swapped to 275 this time and much better. and i think they look better too.
