Tire Pressure Sensor Fault?
FordTechOne
Cobra
Then they weren't OEM. OEM one's are self learning.
The OEM TPMS sensors still need to be trained to the vehicle so that the Body Control Module (BCM) knows the ID of each sensor. Even if you swap wheels and tires with another set of factory wheels and tires, the system will not "self learn" the new sensors. They need to be trained using the proper training tool and procedure.
2015 Silver GT
East Haven Connecticut
2022 Oxford White GT Premium
B.S. I've never had to use a tool anytime I've installed new sensors on new wheels. They just synced up by themselves.
PhillMcKraken
DFW Texas
2016 Mustang Ecoboost
Incorrect. These TPMS are self learning. That's a fact.
FordTechOne
Cobra
Just because they didn't set a TPMS light doesn't mean that the system is working properly.
The module has no way to know which sensor ID is located at which point on the vehicle unless the sensors are trained following the sequence in the service manual. So even though it may display 4 different readings, the display will not correlate with the actual position of the tire.
Once again, you need to follow the training procedure in order to allow the module to learn the sensor ID and location of each TPMS sensor.
347CobraII
iowa
2015 GT
There not going to listen because they don't know any better. All they see is there's no light so it's ok but it's not. They won't believe someone who works on them well because it's internet.
wildcatgoal
@sirboom_photography
TBD
I have a Ford Fiesta rental while my car is in the shop and the TPMS light went on, filled up the tire to 32 cold per the door sticker, and it won't go off. I'm worred Hertz is going to "find something to charge me for"... I wish TMPS sensors never were invented.
347CobraII
iowa
2015 GT
That's because people don't check tires or pressures..... How many times do we see people with 1/2 flat tires A LOT. It's very sad to see how people treat there car or truck. Then call it piece of junk when it breaks when most of it can be prevented
FordTechOne
Cobra
Exactly!
fcarr005
Miami, FL
2015 Mustang V6
Same thing happened to me the moment after I installed the raxiom 4th brake light and led converter :/ it went away on its own but I figure it has something to do with that.
