Tire Pressure Indicator and Gas Mileage
Rapid Red
Woodstock GA
Greg
To start with gas station air pumps are notoriously inaccurate.
Tire pressure should be checked and adjusted on a completely cold tire.
Why would you set your pressure to 40 instead of what the label on the drivers door post lists?
And to mention the cheapest tire gauge is probably better than a SLIME air pressure gauge.
LMAO the cheap tire gauge did match the reading from the TPS
"Tire pressure should be checked cold tire." And the best way to do that, Ford Pass .
2015Pumpkin
2015Pumpkin
Titusville
Chad
2015 Mustang
So a pretty accurate way to figure out your actual MPG. When you pull in to the gas station note how many miles you got on that tank. Then after you fill up take that number and divided it by the amount of gallons you just put in your tank. I.E. you traveled 227 miles, then topped off with 13.589 gallons. 227/13.589 = 16.704MPG.
Good old pencil to paper! LOL
2015Pumpkin
2015Pumpkin
Titusville
Chad
2015 Mustang
What do you mean "supposedly" you inflated them to 40 psi?
Did you use a reliable handheld digital or analog tire pressure gauge?
Why did you set them to such a high pressure?
If you have the original TPMS sensors they are 6 years old and are entering the end of life window for their batteries.
First of all...I DIDNT say I SUPPOSEDLY inflated them to 40... I said PURPOSELY inflated the tires to 40.
I used an analog gauge. I inflated them to 40 JUST to see if the TPMS would also indicate that tire pressure...which it didnt. Lastly...I did not know that TPMS's have batteries...SO...thanks for that info. I will have to remember that when I take it in for the first oil change and tire rotate at the shop! Thanks!
2015Pumpkin
2015Pumpkin
Titusville
Chad
2015 Mustang
Guess Ill be tossing the SLIME gauge into the circular file! AKA garbage can!! LOL
cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
Find a good digital. Just make sure the battery is fresh.
Zrussian13
Phoenix
On my car...
Tpms reads low by a few lbs.
Mpg reads high by about 1mpg.
cactus_kid
Michael
'21 GT (see sig)
Mine is pretty much spot on based on cold tp at startup.
ORRadtech
Atlanta, Georgia
When I get a new car it's standard practice for me to manually figure MPG over several tanks and compare it to what the car's computer says. The car is almost always a mile or two higher than what's real.
JimC
Howell MI
Jim
2019 EcoBoost performance package coupe
Hand calculation is really just another estimate of mpg. Unless you are measuring how much gas you actually burned and replacing exactly that same amount, you are still only doing an estimate. Difference in temperature, flow rate on the pump, how high you fill the tank and fill pipe, or any back pressure is going to affect how much gas you put in the tank and affect your calculation as a result.
Bikeman315
Myrtle Beach, SC
Ira
2015Pumpkin
2015Pumpkin
Titusville
Chad
2015 Mustang
Very true. Sometimes you might fill the tank till it almost runs out and the next you might cheat yourself by a gallon or a half. Good point!!
ORRadtech
Atlanta, Georgia
That's why I do it for several tanks in a row, sometimes for three or 4 months. It takes all the variables and averages them out.
Will it ever be perfectly accurate? No, but it is a good solid average.
