This tire wear normal?
ahl395
Allan
Hey guys,
I know its normal for one side to wear more than the other when doing hard launches from the toe changing. Just wanted to see if this extreme was normal or not. Tread very low in the middle, not as bad on the side, but far side has belts showing through.
Tires are 305/35/19
ahl395
ahl395
Allan
I did have it aligned and bushings clocked after it was lowered, but maybe it has to be checked again.
Tire pressure i keep between 28-33 when I check it which I think is in the normal range.
robwlf
phila
rob
17 lightning blue pp LFP 670
thats tire pressure for sure ..think theres a chart on what happens with either low or high pressure and pics of tires with with either or. damn that inside wear is bad
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
Center going out like that is due to tire pressure, if the outside wore out its from not enough pressure
The inside wear is from your toe
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Toe?
ahl395
ahl395
Allan
Probably a good idea to have it checked out, especially with your new winter set up.
Yeah, I'm gonna have it checked
I filled them to 30, highest I recall seeing them on the dash screen was 33, maybe 34, depending on temp and driving.
Paul, these are the M350's and MPSS I purchased from you, what do you recommend for tire pressure? I believe it was 30.
I had it aligned to factory spec after lowering, will have to get it checked though
