WD Pro
- Jan 18, 2018
- United Kingdom
- Lime GT
- Vehicle Showcase
- 1
From another thread, but here is what I posted on my running in procedure :
WDI also posted this info on the MOCGB forum after an owner on there has got big oil consumption issues after a ‘gentle’ running in procedure – seeing as how this thread is my car journal I might as well add the info in here :
Hhmmm, that’s very interesting and a dilemma that I was also faced with.
I did a lot of reading and came to the conclusion that the spray in bore lining of the gen 3 engines is very hard and needs a reasonably tough break in period.
I use the Mustang as a second car so I got the choice of when and where I drove it (and who I had in the car with me i.e. no kids), I guess that helped a lot.
I applied these rules :
- I am mechanically sympathetic (letting it warm up properly etc).
- No letting the engine labour (no driving under 2k – other than the first gear 0.5 mile run to get me off the estate / over the speed humps).
- No cruise control (other than checking it worked).
- No 5th or 6th (other than checking Ford remembered to fit them in the box).
- 4th only occasionally (only when road speed was quite high).
- No constant throttle (I was pretty much either on the gas or letting it overrun).
- I used full throttle as often as possible (once ‘properly’ warm), but I limited the revs as per :
Off the forecourt = 4k100 to 250 = 4.5k250 to 400 = 5k400 to 550 = 5.5k550 to 700 = 6k700 to 850 = 6.5k850 to 1000 = 7k1000+ = still experimenting with the best place for the shift light so I don’t buzz the factory limiter.
- I used the factory shift light set to the above schedule to remind me when to change, I might have ignored it on the odd occasion …
About 90% of my running in was done at night on quiet roads and maybe approaching 30% of that was done on either a local dual carriageway that has traffic lights approximately every 0.7 miles or another section of dual carriageway that’s 0.4 mile long with a roundabout at each end. Both roads have a good surface and no residential or business properties on them and no side roads, junctions or bridges i.e. perfect fun roads for repeat cycles of acceleration and overrun ;-) (side note – the diff warms up very quickly on the 0.4 mile roundabout road).
After 500 miles I started to use the brakes with a bit more anger (pulled a 1.04g after a gauge reset and a high to low speed brake i.e. not just a sharp jab of the pedal).
I only really started to rush the gearbox / clutch after about 750 miles.
I think my oil consumption and what my breather caught is pretty low, especially for the first 1000 miles and also considering how I ran it in – can’t say the same for my MPG though … lol. That’s hovered between 12 and 14 (UK gallon for any of our stateside friends reading this), but that’s not really what we bought these cars for is it …
Time will tell how it all worked out but as this cars bought outright and is a keeper, it will be me that has to live with my decisions.
Maybe the nut and running in info will be useful / interesting for some, maybe it won’t …
WD
