Thickest spacers with stock studs?
Swedish_Fries
Function and Form
Austin TX
15 Guard GT
Toss a 25mm adapter on that bad boy.
Competition Orange
Columbus, Ohio
2017 GT350
I threw 5mm spacers up front and was able to get 6 turns of the lugs. I'm happy with the results.
I'd like probably 10mm, but don't want to do the studs/hub yet.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
6 turns sounds good, its the minimum we recommend. The 5mm is still enough to show the difference when spaced out. Enjoy:headbang:
xXANCHORMONXx
SF CA
2016 GT350 Track Pack
Rule of thumb with and nut going on a bolt is that the nut should go onto at least the thickness of the bolt.
So if you have a 1/2 bolt the nut should go on at least 1/2
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
This.
6 threads is approximately 12 mm. Probably fine but another thread would be ideal.
