Manders Mustang
The Boss
- Dec 3, 2015
- Birmingham - United Kingdom
- Steve
- 2016 Race Red Ecoboost
- Vehicle Showcase
- 1
Mine are sealed with Butyl, easy enough to remove as it's a rubber sealant, it goes hard, but it's still malleable, can just pull it back out if I need to.I wish there was already a DIY solution for the taillights.
For the fronts the idea with the template is great, I do wonder if it would be possible to 3d print a mold/seal in rubber to close the lights of again. Anyone?
I mean, if you 3d print a mold based on the edges of the template with a bit of overlap on both sided you could slide the cut out piece back in to place without glue or silicone and reopen the headlights whenever needed and also have a clean looking finish.
Just an idea!
Rubber 'bung' does sound quite a good fix to it though, could work.
Rears is plug and play solutionised now (even with a switch, installed mine in 5mins)
