T56 swap questions
cole9725
Phoenix, AZ
I am in the process of swapping over to a T56 magnum in my 2018. I previously purchased a Lpxhd clutch for the 18 mt82. I sent off the discs to be resplined to 26 spline to McLeod.
My question is..will the 2018 flywheel with resplined discs work with the T56? or do I have to change out the flywheel as well??
J17GT
IL
2017 Mustang GT PP
Yes, it will work with the t56 magnum. You will also use your stock slave cylinder as well.
I highly recommend taking the measurements in this article to be sure the hydraulic slave is in the right place: https://www.mcleodracing.com/blog/h...-using-hydraulic-bearing-t-56t-56-magnum-/201
Mine was not and I blew the slave out on the second WOT shift. I now have a shim behind the slave and all is well. My case is not typical it seems, but best to be sure.
