System audio not playing through speakers
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
I noticed this recently, the door chime and reverse beep are playing through the system/instrument cluster speaker and not the audio system like they used to so they sound different. The only thing I did was plug back in the telematics fuse since I'm going in to service soon. May have had something to do with it, but I don't know where to check first. Everything else works fine and I'm on the latest version of sync software. Before this it already stopped lowering music volume when I was backing up like it used to.
ice445
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Problem solved, apparently the battery was just low from the cold snap and sitting for a week. After a longer drive, all is well.
If anyone else runs into this, apparently the car normally boots up the infotainment/audio system when you open the door, but if the battery voltage is below a threshold it will not until you have started the car. If this happens, the car uses the instrument cluster speaker as a fail safe mode and will not switch back over, even once the audio system has booted.
