sve gt7 11.5 wheels
Venom94
Ontario canada
Lathan
2016 mustang gt premium
anyone know if its possible to run a 19/10 front 19/11.5 rear setup on a non gt350 gt?
Venom94
Ontario canada
Lathan
I called them and they said it wouldn't fit a gt cause the backspacing is different for the gt350s over the gt
MRRDesignWheels
Los Angeles
Mustang
Maybe they are playing it conservative but a 19x11.5 with a 56et fits 100% with a 305/35/19 max is a 325/30/19
talk to paul from PK auto design also a supporting vendor and guess what our M600 is on sale right now,
just saying. :like:
Venom94
Ontario canada
Lathan
Damn Carlos that's a really good deal. Do you guys have a 350r replica wheel ? And how concave is the m600?
Venom94
Ontario canada
Lathan
I was leaning toward the m600 but when I looked on the forums I saw 2 types of issues people had with paint peeling and the other issue being the boles not perfectly bored so I was a bit apprehensive
MRRDesignWheels
Los Angeles
Mustang
we had a small issue wit our equipment when doing custom finishes a while back, unfortunately our temperature from our heating oven was not reaching the proper requirements and some had paint issues but if you speak with any of those clients we took care of each one and our system has been ruining with proper heating temperatures .
the M600 is made solely for Mustang applications so we do not compromise on specs, we have 3 CNC techs on hand and not one wheel structure failure.
Venom94
Ontario canada
Lathan
That's great news does it use special bolts or can it fit other sizes?
MRRDesignWheels
Los Angeles
Mustang
PM sent
standard 14x1.5 lugs is all that is required.
Ohthatguy
Jax, FL
2018 Mustang GT Auto Lightening Blue
just saying. :like:
On your M600 in 20x11, how much clearance is left on the suspension side? I’m curious because the 19’s in the 11.5” width sit around 12mm closer on the suspension side but still have room for 325 Michelins. Think a 20x11 offset 60 would work with a 325/35/20 Tire?
MRRDesignWheels
Los Angeles
Mustang
I wouldnt go that high on a 20" 55-56et has been the perfect fitted whee option /.
but here is the math
if a 19x11.5 55et gives you 12mm of room inside a 20x11 55et will give you a additional 7mm of clearance BUT the wheel will also be 5mm more in from the outer side
so yes you have room to go to a 60et but then the rear wheels will look like those cars that get a 2 inch wide body but rolling on stock 19x9.5 50et wheels.....
im exaggerating but you get the point right?
Ohthatguy
Jax, FL
Ha, okay, thank you. Yes, point taken. I was curious if the inside room was there or if 20’s / taller tires had to stay further away from the suspension side than say a a 27” tire for some reason. I appreciate the feedback!
MRRDesignWheels
Los Angeles
Mustang
:like::like::like::like::like:
