Stuck on removing 2018 dash
drumstick
Oklahoma
2018 GT
So I think I got all the bolts and clips off the dash, but it still wont budge.
The only things I haven't taken off yet are the side bolts that connect to the metal bar that runs behind the dash. Do those bolts need to be removed (pictured below)? I didn't think the whole metal bar comes out with the dash.
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
O man ! You need to loosen the jam nuts between the dash support and a pillars. Also dont forget the two bolts under the plastic cowl behind the wiper motor. That whole dash comes out with the support and harness. Could uave left the radio and cluster in and some other stuff but no biggy. Good luck
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
Also the 4 bolts in the door jamb have to come out as well as the ones you pointed out. Along with the 4 bolts holding it to the trans tunnel
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
I got a bag if youneed one
drumstick
Oklahoma
2018 GT
Thank you!!
Which are the other 4 bolts in the door jam besides the ones in the pictures above? Only;y others I see are the door hinges.
Does the whole shifter have to be removed? 4 bolts on top and the cable on bottom? It’s a auto car.
Remove the upper half of the steering column too? Looks like just one torx bolt.
