Strange noise.....Any help
dark_termi
Wheatley Ontario Canada
Frank
2016 gt350
After 2 weeks of not driving my 1500 mile gt350 I decided to take her for a quick spin. Apon driving it off the driveway it starts to make a strange noise like it has a flat. Noise is coming from the front drivers side wheel well. Its more noticeable when driving slower and you can only hear it once every full wheel rotation. Anyone else with a similar problem?
Thanks for any help.
sweetchuck2001
Ohio
16 GT350, DIB, Tech package.
Sounds like a flat spot in the tire. Should normally work itself out just driving around for a bit
RadBOSS
Paso Robles, CA
69 BOSS302, 29 Model A Roadster
I would get the car up on a lift and do a visual, rotate the tire(s) while doing this to see anything abnormal (like a bulge, nail, etc).
Also check to make sure the shipping blocks have been removed from the springs.
stanglife
Jeff
1993 Coyote Coupe
If you washed it before putting away, it's likely some rust formed on the rotor under the pad (would have stayed wet for a longer time where the pad covers the rotor). Hit the brakes a little harder than usual and see if it cleans up.
dark_termi
dark_termi
Frank
2016 gt350
Thanks fellas for the info, I took it for another spin last night and exactly what stanglife had mentioned happened. I've washed it a few times before driving it again a few days later but this time it was bad. Just a couple of brisk stops and it cleaned them right up.
