Glad to hear it - we appreciate your support & order!Mine shipped today
Best Regards,
TJ
Let me look into this for you ... I have an email into our manufacturing dept. for support.how much wider are the mounts than stock? are they angled similarly? can you post a side-by-side showing the difference? reason i ask is that i'm running 18x12/335 and rubbing ever so slightly under heavy cornering, and have no additional room outboard unless i cut fenders (already pulled 10mm)
Hello,how much wider are the mounts than stock? are they angled similarly? can you post a side-by-side showing the difference? reason i ask is that i'm running 18x12/335 and rubbing ever so slightly under heavy cornering, and have no additional room outboard unless i cut fenders (already pulled 10mm
Great question - let me also look into this for you.David or TJ, any plan to include better quality bolts to replace the one time use stock bolts?
Oh and by the way, these look awesome, great idea!
ok, check - no additional clearance.Hello,
I just received feedback from our manufacturing team & unfortunately, our mounts do not provide any additional clearance.
This may be something that we consider & look into as a future project.
Best Regards,
TJ
I spoke to our team & the factory bolts seem to be very strong.I am also curious about new bolts. Keep us updated Tim! Thank you in advance!
Double checking - stand by!my real concern is that they provide *less* clearance than the stock mounts though. can you confirm that they mirror the stock mount footprint?
They are slightly larger than stock, the reason they are much stronger then stock.ok, check - no additional clearance.
That's great news! I see a set in my not too distant future!Update - Next week we will release the billet rear shock mounts with a 1/4" more clearance then stock!
This will be great for lowered cars & meatier rear tires.
Best Regards,
TJ
Thanks TJ, that's good to know. I've had those 1 time use bolts in and out probably 5 times now.I spoke to our team & the factory bolts seem to be very strong.
No current plans to provide different bolts.
Best Regards,
TJ
