Bluemustang
Yeah me too. The shop says the tie rod is completely parallel to the lateral link. They measured it a few times with a level.Leads me to believe they didn't set it up right before...
If true, that could also explain some of my previous bumpsteer complaints.Leads me to believe they didn't set it up right before...
Yeah. Exactly parallel isn't necessarily just right, as the steering link and control arm lengths and pivot point widths are different, but it's a very good starting point.If true, that could also explain some of my previous bumpsteer complaints.
Actually thinking back what he said was it was completely parallel to the "steering rack". Not quite sure what he is referring to.Yeah. Exactly parallel isn't necessarily just right, as the steering link and control arm lengths and pivot point widths are different, but it's a very good starting point.
I'm not him but I can chime in...Hey Bluemustang, I am ready to purchase the same Steeda front suspension items with bearings that you did but I'm having second thoughts with the bumpsteer kit. I'm lowered on an Eibach pro-kit, and have Steeda's front sway bar, their G Trac K Brace, and my front tires are 285/35/20's on 20x10 wheels. (Maybe some of those items don't come into play, but just wanted to mention them in case). I really don't have any issues with the factory bumpsteer other than my steering isn't as responsive as what it was, but I thought maybe it was because of the wider wheel and 285 tire in the front. Do you feel you REALLY needed the bumpsteer kit? As in, can you install the other two items (555-4909) and be fine with the factory bumpsteer set-up? We already spend loads of cash on our cars and a little more definitely won't bother, just want an opinion.
The factory has no bumpsteer setup. Just a one size fits all tie rod end with no adjustment. The factory has no way to mitigate this / adjust to remove bumpsteer.
If your going with the lateral link with the extended ball joint stud, you should be using the bumpsteer kit. If not skip the lateral link or you may have some undesirable results with induced bumpsteer.
If you go with the lateral link with the extended stud it will increase the angle on the lateral link, placing the outboard side closer to the ground. You'll have no adjustment on the outboard end of the steering tie rod and whatever you end up with is what you end up with in regards to their relation to each other (lateral link / steering tie rod).
I would think you'll end up less than optimal and could/will experience bumpsteer and less sharp turning response. You wont be able to drop your tie rod end down with a bumpsteer kit to match the same angle the lateral link is sitting at with the new extended ball stud.
@steeda can chime in, but I asked them the same thing in the spring when I did all my suspension and they said the 2 are recommended to be installed together. They compliment each other.
Yea as Dr. Norts said you will need it. And I think you need the RC correction due to how much you are lowered. You should see a bigger improvement than me because of the Eibach springs. It seems to be the larger the drop the greater the benefit.Please, chime away. I'm no expert by far with suspensions, so thank you for the response. This clears things up a little better for me. I was figuring going with all three, but just wanted to make sure. Thank you.
Yes, you would need the Bumpsteer kit with the extended ball joint that's a must.Hey Bluemustang, I am ready to purchase the same Steeda front suspension items with bearings that you did but I'm having second thoughts with the bumpsteer kit. I'm lowered on an Eibach pro-kit, and have Steeda's front sway bar, their G Trac K Brace, and my front tires are 285/35/20's on 20x10 wheels. (Maybe some of those items don't come into play, but just wanted to mention them in case). I really don't have any issues with the factory bumpsteer other than my steering isn't as responsive as what it was, but I thought maybe it was because of the wider wheel and 285 tire in the front. Do you feel you REALLY needed the bumpsteer kit? As in, can you install the other two items (555-4909) and be fine with the factory bumpsteer set-up? We already spend loads of cash on our cars and a little more definitely won't bother, just want an opinion.
Thank you,
Steeda Tech
Thank you all for the responses and insight. And for helping me spend my money.Yea as Dr. Norts said you will need it. And I think you need the RC correction due to how much you are lowered. You should see a bigger improvement than me because of the Eibach springs. It seems to be the larger the drop the greater the benefit.
LOL. BUT.. you are going to have more fun afterThank you all for the responses and insight. And for helping me spend my money.
Thanks @BmacIL that is what I was thinking. Nice to confirm that. Based on this assumption I think it was right for me to go to a softer rear bar prior to this to compensate for the increase in front grip.Raising the roll center will typically reduce grip on that end of the car from the reduction in roll couple, similar to what an anti-roll bar does. However, because of the strut suspension design, raising the roll center will often increase camber gain enough to improve overall front grip more than the reduction in roll couple would.
