Steeda Differential Bushing Kit
1badrz28
Woodbury, MN
I'm hoping someone may have a kit that isn't installed yet and would be able to help me out and mic the two different size steel bushings that are inserted into the poly bushing. The ID's and OD's should be the same, but have different lengths. I'm looking for all three dimensions.
I have the bolt sizes from Steeda' installation directions, but they are lacking the steel insert size.
Any help would be great.
Best, Jim
VinnAY
Kansas City
18 Camaro 1SS/1LE
You can plainly see on the instruction sheet and @ youtube/cj which parts go where...you're not trying.
1badrz28
1badrz28
Woodbury, MN
I know where the parts go. If you read, I was asking for the steel insert sizes.
I purchased the black bushings from someone who didn't use them, and plan on piecing the rest of the bolts and inserts to finish the kit.
bscn8c
Certified BADASS
Arlington Heights, IL
2016 Mustang GT PP
Just contact Steeda. They will respond quickly. I had a question about the specs on the bolts in the kit, and all it took was a 2 minute phone call.
1badrz28
1badrz28
Woodbury, MN
The MFG was already contacted. So, I figured the forum was the next step to help get an answer.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
You must want to hear gear noise in a bad way with steel/ poly bushings....
tj@steeda
Timothy
We are adding the replacement bolts & inserts to the site - it will be a replacement kit that you can purchase to install them as intended.
Best Regards,
TJ
