Squishy Pedal After Stainless Lines
lava5oh
Orange County, CA
Mustang GT
I installed Stoptech stainless steel front brake lines today, bled the brakes, tightened everything down and have a squishy pedal while the car is running. While the car is off, it is able to build pressure normally, it's only squishy when the car is running.
I checked all lines for leaks, made sure everything was tight, and everything checks out. I bled the brakes again, and am now stuck not knowing what the problem is.
Any help would be appreciated!
w3rkn
Detroit
bmw 135is(sold)
How badly did the brakes bleed..? You might have a vacuum leak, taking in air..?
lava5oh
lava5oh
Orange County, CA
Mustang GT
Vacuum leak was the only thing I was thinking. Nothing was wrong prior to changing the lines though. That's all I changed.
Try bleeding the brakes again, starting furthest from MC and working your way back. It sounds like you have air in the system.
Are you using a 1-man bleeder setup, or doing it the old school way?
lava5oh
lava5oh
Orange County, CA
Mustang GT
I am happy to report that I'm an idiot. First time ever having 4 piston calipers... I never drained the other side of the front calipers. That solved the problem. Thank you all!
texasboy21
Houston
2017 GT PP. 2005.5 Audi A4, 1983 Silverado
Definitely air in the lines!
Did you use a pressure bleeder similiar to the Motive power bleeder? Makes bleeding the brakes MUCH cleaner, easier, and faster.
Curious, does the clutch slave share the same fluid and reservoir as the brakes?
lava5oh
lava5oh
Orange County, CA
Mustang GT
I did not use a power bleeder, old fashioned tube and bottle haha!
Yeah, the clutch shares the same reservoir as the brakes.
texasboy21
Houston
I presume you bleed the clutch as well?
