spark plug choice and gap for bolt on, tuned EB's
Status
Not open for further replies.
boosted_orange
San Antonio, TX
Alex
2015 Ecoboost PP
I picked mine up at my local Napa auto parts, rock auto was cheaper by $7 but they had them in stock & didn't want to wait a week to get them..Lol
Gst95dsm
Fresno CA
2015 MM EB PP Recaro....
Im assuming the fuel is as good as I can get. OAR easily adjusts down to -1. I'm out testing right now and have not been able to duplicate the problem. It was much warmer earlier today though....
Do you have good fuel in it? What's the oar at? I think maps tune is pretty aggressive,hopefully plugs fix it.
Apwrx
Oregon
Magnetic premium PP
Well hopefully it was the plugs then, it'll be ruled out I guess when it's warm again.
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
I thought their tune was a bit more on the conservative side unless all of your bolt-ons were from MAP? I'd like to see a dyno comparison of the stock tune vs their custom tune for a stock car.
Sent from my Nexus 5 using Tapatalk
tanna786
Michigan
Tan
2015 Ford Mustang Ecoboost
Hey guys, I'm new to this forum and just bought my 1st Mustang so I'm a rookie when it comes to performance and modifications.
Just installed my Livernois tuner 2 days ago and read somewhere in the forum something about spark plugs need to be gapped after being tuned , does that sound right?
If so, I wasn't informed that needs to be done?:shrug:
any information would be appreciated.
Juben
Chattanooga, TN
Justin
Here's a thread I started about colder plugs. It has info on what plugs can be used, what the benefits of colder plugs are, etc.
http://www.mustang6g.com/forums/showthread.php?t=16766
ronemca
ON Cda
Ron
2016 P/EB w PP
Are there torque specs available on the 2.3 for the spark plugs? Quick search and I couldn't find them. Thanks.
10 foot pounds
Rob0381
Kansas
Rob
2015 Mustang RS1 Premium W/PP
What is the factory gap requirement for the EB?
Will switching to NGK at .028 on a cat back only EB make any difference?
jbailer
Joe
Stock gap is 0.0295. No, switching to a colder plug on a stock tune with a catback will not make a difference. Everyone hears about running a colder plug and thinks if they just put a 1 step colder plug in, their car will be faster. Trust that Ford did a lot of engineering to determine the best range for the plug to operate. Ford Performance even stuck with the stock plugs and gap for their performance tune for the ecoboost. Putting colder plugs in will just have them operating at too low a temp and they foul easy. With a pro tune, yes, they push the operating limits and benefit from a colder plug. Some of them also push more boost so reducing the gap helps prevent spark blow out. You wan to run the largest gap you can without getting spark blow out to ensure the complete and even burn of the fuel in the combustion chamber. I have the stock plugs gapped at .029 and they're working great! I pull them and inspect them every 5k miles during oil changes.
BoosTang23T
2016 Ford Mustang EcoBoost
I just changed mines using the TUNE+ pre-gapped NGK ones. I created a video in case anyone needs help.
[ame]
BoosTang23T
I believe Adam says to torque to 10lbs on his website.
Missed that detail on his site! It's been running fine with 18lbs, so hopefully it's fine.
jrock
The
2016 Blue EB
BoosTang23T
Should I loosen mine up then?
Status
