Spacer question.
atlas10Spd
california
2022 mustang gt, 2022 chevy silverado
I actually used a hand held drill. All you are going to do is drill out enough material to allow clearance. Start by putting some paint on the tip of the wheel studs and reinstall them. Then remove the wheel and the paint will transfer to the spots that will be drill. Start with the 9/16 and drill about a 1/8" deep. Repeat the paint transfer step. iF necessary go a little deeper(but only a little). If the C'bore needs to be wider due to drill walk then clean out the C'bore with the 5/8" drill bit.
sorry if I wasnt clear enough what did you use to c bore?
1 old racer
Fontana CA
Will
Just a plain 9/16 and 5/8 drill bit. Mark the spot you want to drill with a center punch in order to reduce the chance of drill walk.
atlas10Spd
california
I see so you basically drilled with the bigger bit and cleaned up the cone with the smaller bit? I apologize for the amount of questions I am planning on doing this soon.
