Some Laguna Seca footage
xXANCHORMONXx
xXANCHORMONXx
SF CA
2016 GT350 Track Pack
How did you like the Cortex DSC, did it work out for you? Did you change it up at all or run it the way it came in the box? I'm looking at buying one in a week or so. Curious to hear your feedback. I wish I would have known about the track day/race, I live 15 minutes from Laguna Seca. Way to represent the GT350's.
Damn
I've posted a few times about trackdays but typically no one bites.
I'm runniing redline time attack July 23 in BW FYI.
First of all the directions are slim to none from cortex. The install is easy but I had no idea about the features.
With the controller there's the standard normal and sport but also track mode which is activated when you go into track mode.
I used the tune from cortex on it and it seems good.
His tuning was done on a R.
On my car I have spherical bearings at every joint or delrin with the R springs.
The only thing I don't have is the r dampers. I will either up the sensitivity on the current tunes or get the r dampers
The biggest thing I have to say is consistency, the car is easier to drive fast with the controller. My best time from a month ago was a second slower then my consistent time on Sunday.
firestarter2
NYC
RR G350 Track
Thank you, yes it is 100% plug and play. Super easy to use, it's a real bummer.
I need to figure out my GoPro and Harry's LapTimer overlay, hopefully it will work at my next event.
With Harrys you will need a external GPS. I have not had much luck with the GO PRO it seems a finicky. Ill try again next time.
