Rapid Red
- Nov 4, 2019
- Woodstock GA
- Greg
- GT PP2 RaceRed Roush> Steeda> preformance
- Vehicle Showcase
- 2
If you look at the picture in the first post. The hydraulic system which is 7A453 can go bad. So this issue can be caused from a defective pedal hydraulic system or the slave cylinder/TOB. Either could be the issue so I guess if it’s covered then why not replace both.
I think you're missing the point of what the pedal does.
Lets change the subject, casue the next thing I going to mention. Uses the exact same type of components and operation to preform a different operation.
And what might that be ? Sitting in the car slide you foot over the the next pedal on the right.......... its name the brakes.
MC goes bad the MC is changed, like I said you do not change the wheel and tire to fix a flat
