Adaraas
- Feb 13, 2015
- Central FL
- Austin
- 16 Premium GT, 17 Laramie Cummins
Original 2016 Block. Sleeved with stock bore pistons Stepped sleeve. 11:1 Compression
Currently has about 5k Miles on it.
Callies Rods, Diamond Pistons, OEM Crank. Trick Flow valve springs. full arp catalog main studs/sidebolts/rod bolts/head studs.
Has King rod bearings, OEM main bearings. ATI Balancer.
Has a 2018 GT manifold
Included is my breather setup.
I'll include my Fore stage 4 Rails, but only the rails as I'm reusing the rest.
Oil changed every 3k Miles with 10w50 castrol
Built by Collin@Racing Intergration in tampa.
Located in Central florida, but I'll drive up to 3 hours from Brooksville area to meet you/drop it off.
Asking 9k For complete motor/ECU. Just drop in, add your injectors and go. Alternatively Make me a reasonable offer.
I can also include My transmission and Circle D 3C Converter for 10.5k or again make me an offer. thanks
I'm not sure if the ECU will work or not. I know it doesnt work when doing coyote swaps in older cars cause of the BCM, but maybe it works in 2015 cars? Either way I'll include it as I have no need for it.
I can have the motor out of the car in about 3 hours. let me know, thanks.
