SallyStang
- May 26, 2020
- Pompano Beach Florida
- Susan
- 2016 Mustang GT
Hi all, I've been reading and reading these forums. I have had this problem and should have brought it in while my 2016 convertible was under warrante but didn't. When I am driving around town I loose signal always at the same place on certain roads. When I am on I95 in Ft. Lauderdale it loses and has to acquire the signal 4 times within two miles. I have navagation and that works fine. (my understanding is the gps and sirius are in the same antenna). I had a problem with the backup camera and had to re-solder that cable . I know of the issue with the harness at the trunk lid but I have fiddled with wires and felt the antenna wire in the harness and I can't feel a break and messing with the harness at the wear area doesn't change anything.
I would think I would get no signal if there was an issue with the wire.
Is there any way to check the signal strength? Or test the antenna. I have an old sirius antenna but it won't connect to the harness. I was reading the bulletin I found on this site and I says not to slice the antenna wire and I would have to run a new antenna wire from the trunk all the way to the head unit. I might be willing to spend the 2.8 hours to do this if I knew it would work.I wanted to reactivate my subscription but it's not worth it unless I can figure this out. I updated to sync 3.4 and still have the same issue - though I don't have a current subscription it losses signal on the preview chanel.
I would love to hear any suggestions you all may have!
