Short Throw Shifter
CamiloBedolla
Napa Ca
Camilo
Mustang Bullitt
Mgw race spec or Barton Hypbrid 3 Any suggestions or Experinces with any? Having a hard time deciding. It’ll be going on a 19 Bullitt
FreePenguin
Ohio
Donald
17 mustang
Hybrid 3 here. Paired with steeda clutch spring was great, perfect. But made it even better w bg synchroshift ii fluid in the case
whwn warmed up it is equal smooth as Oem. It’s just. Oem was slightly notchy when cold, the bg was 90%smoother with cold fluid
both warmed performed same smoothing Oem vs bg fluid
CamiloBedolla
Napa Ca
Camilo
Mustang Bullitt
The real difference is which style reverse you eant
you either get push down style w mgw or Oem pull up w Barton
Perfect already got the steeda clutch spring, Appreciate the suggestion
krishelnino
Detroit, MI
Krishna
2018 GT Premium MT82 Race Red
MGW X-spec with BG Syncroshift trans fluid is just so good. You won't regret it ! The push down is no big deal which you'll get used to, and there's hardly any increase in NVH, mostly it's just shifter vibration which you can feel.
FreePenguin
Ohio
Donald
17 mustang
I went Barton since my other car is pull up. No regrets. Either will be fine, but muscle memory I didn’t want to get mixed up going car to car
fuelforfire87
IL
2014 Shelby GT500
MGW X-Spec standard. Steeda SS line and spring, lethal LPX-HD. RP trans fluid. Feels nice.
ZPD
TX
2017 GT Premium
Hadelson
Allentown, Pennsylvania
Hugo
24 RTR Spec 3
I've had both the Steeda and MGW on this ride. MGW on last Mustang. Both are good shifters, but I am much happier with the MGW. Also with it I've installed the braided SS line and Steeda Spring. I've also settled on the BG Trans oil.
CamiloBedolla
Napa Ca
Camilo
Mustang Bullitt
Didn’t even think about new trans fluid I will definitely look into that!
CamiloBedolla
Napa Ca
Camilo
Mustang Bullitt
That was one of the reasons why I couldn’t decide the pull up to reverse or push down, Probably should keep the push up then Thanks
jacknifetoaswan
Charleston, SC
Check06
Socal
Evan
2016 Mustang P1X GT
Barton hybrid 3 mounted to the trans. i like the feel/rumble it gives being mounted to the trans, no problems/lockouts with high rpm shifts to 7800 etc
