Short throw shifter shifter ball options
Bcintron19
Brandon
2019 Mustang GT
I recently installed a steeda tri-ax race short throw shifter and have been having trouble getting the shift knob to stay attached onto the threads. I was looking at the MGW shifter balls, does anyone know if that will fit with the shifter I have?
TrackMustang
SoCal
2021 Mustang GT
I have the ford performance one and had to take the nut out. I used a bit extra locktite and it’s been good to go. Just make sure the reverse collar functions before you set the knob.
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
The shift knob is fine. Changing it won't solve the issue, unless you manage to find one that just happens to have the thread exactly as long as you need.
Use a bit of blue Loctite (not red!) or a locking nut. Problem solved.
WD Pro
United Kingdom
Lime GT
This.
Put the car in reverse, screw the knob all the way down, back it off to the first almost level gate pattern, put it in third, level the gate pattern exactly and then leave it overnight :like:
WD :like:
tj@steeda
Timothy
We've gotten this question more than we'd like to admit, so we thought a video would be the best way to answer. You may think a shift knob is a no-brainer, but people forget important steps that can lead to serious problems. Check out this video with our head technician, Jamie, and how to properly install your shift knob. No more problems with it coming loose, being crooked, or coming off completely.
