Shaking / vibrating hood at high speed
Tubalkayne
First Time Mustang Owner
Largo, FL
Brian
2015 Mustang GT, Steeda PP, Competition Orange,
So I stretched the legs out on Inferno today and when I hit about 120mph the hood started shacking, is this normal due to the pressure under the hood and the hood vents? the car did not fee unstable at all and performed fantastically but the visual concerned me.
Barrel
Hoonigan
Cars and Trucks
I doubt that's expected behavior. I haven't had my '15 up that high, but I had my '11 up to almost 160 and there was no shaking.
Trackaholic
2003 350Z, 2016 GT350, 2018 Pacifica Hybrid
There have been several threads about minor issues with the hood alignment. In those cases the latch was too tight or the posts too long, pulling the hood down in the center. In your case maybe the latch is too high or the posts too short, allowing the hood to rattle. So, you might check the latch and posts. IMO it should not rattle.
-T
Tubalkayne
Largo, FL
Brian
-T
That would make sense as the hood gap towards the fenders (both sides) is larger than in the center where the latch is. I'm going to the dealership today; I'll bring it up to them when I'm there.
89Trooper
Central Florida
Tom
2015 Mustang GT
Five Oh Brian
Mustang Guru
Pacific NW
www.KorumFord.com
Brian
11 GT500 Glass Roof Coupe
This was a common occurrence with the early S197's, even after aligning the front bumper stops on the radiator cover. On my '07 GT, I simply shimmed the hinge bolts up with washers, thus raising the rear of the hood a bit to let air out over the cowl area. Cured the high speed shaking.
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
Same problem on my '05. Wish I would've known about that fix.
Tubalkayne
Largo, FL
Brian
Yeah it was easy, they turned the rubber stoppers and couple of turns and said to try it out again. If it's not right I know how to adjust it now.
Blue_Eyes_Lover
San Diego, CA, USA
'15 GT
Can someone show me where these rubber stoppers are or where I can shim in some washers? It's very discerning when I see my hood bounce around like that. :(
GoBlues38
St. Louis, MO
Scott
2015 Mustang GT, Premium, 3.55, 20" Foundry, 6 Spd
Mine shakes a good bit above 80mph
I took my car north of 80 this morning and the hood came up quite a bit by the cowl on the drives side.
Any idea on what to adjust to fix this?
FordService
Ford Customer Care
Dearborn, Michigan
Mustang
Hey GoBlues38,
Shoot me a PM. We'll get her to a dealer to have this checked out. It's best to be safe and make sure there's no major issues.
Jeff
