Senior needs help with "resetting" A10 transmission
PoCoBob
Port Coquitlam B.C.
Bob
2019 Mustang GT Premium, 2016 Edge Sport
Anyone confirm if Forscan is necessary or if the battery method described by Jetscan above ,who is I think, a Ford tech works?
What a Ford tech told me to do was disconnect the negative battery post and then place something on the brake pedal that will push the pedal far enough down to turn the brake lights on (if the battery was connected). Then leave everything alone for 30 minutes. I think that would do the same thing the guy in the video was doing, creating a closed circuit and bleeding off any remaining energy in the system.
I needed to replace my battery a couple months ago and in just the time it took to swap them over my transmission reset. I can't believe how much better it shifts after changing the battery than how it shifted before.
Lbj
Washington court House OH
Larry
2019 mustang GT. A10 auto
Have you had the transmission fluid check My transmission had some problem going in drive or reverse when the car was cold i check the fluid and it was almost a qart low..
