SCT X4 help
ugstang17
unknown
none
If an SCT firmware revision is required the software will advise you to flash the factory calibration back on the car before performing the update OR as mentioned above saving the factory firmware calibration (aka factory tune) to your PC device before hand IIRC. Other gernal software updates usually do not.
I have truly come to detest SCT use on S550 Mustangs. The Ngauge device (whether Lund specific or the ngauge standard used by all others) it is simple and straight forward. Datalogging is a breeze. Copying tunes to it requires no special software. A USB cable and a PC device is all that is needed. The gauges function and everything on the device is very straight forward. SCT seems to have computer geeks obsessed with software more so than hardware ease of use for the customer. The only plus for the SCT is that you can make custom datalog files with the Live-Link II software. Converting that into a file capable of being permanently added to the SCT device as to eliminate the need for PC interaction is more complicated. Another conversion is needed and if not mistaken the created new file then has to be added to the handheld via the tune update software. I only keep the Livelink II software on my laptop these days because it will open and graph out any .CSV file created by any handheld tuner device that generates such a data file that can also be opened in excel spreadsheet.
As mentioned above if you have not used your SCT handheld to update a tune in months (most don't after they are done) tons of updates pop up. On my X3 for the 14 I always ignored these and never had ANY issues - including firmware. On the X4 with the S550 it was a different story and I learned to hate the acronym SCT after using them exclusively for 4 different cars over the years.
Andrew@Lethal
West Palm Beach Florida
Andrew
I plugged in my SCT X4 to the laptop to get updates. SCT device updated said new software was available so downloaded it. Now my SCT X4 won't connect to my vehicle. It says it is married to my VIN. I am getting general error 11046 & 11047. I've been trying to call SCT tech support for hours. Anyone get this error/happen to them? I don't know how to fix this. HELP!
SCT does have decent tech support when you get a hold of them. They will actually download an app to your computer where then can pull the files and logs themselves so you don't have to. Technology is just plain and simple a pain in the butt unless you're around it everyday. We like to recommend the Ngauge due to it being easier to use and navigate. We sell them here at www.lethalperformance.com
nrm101
Mass
Nathan
2019 Mustang GT Premium
I would second that there support was good, i had an issue with datalog that the vendor put on the device (i didn't realize it wasn't a stock one from SCT) Tech support walked me thru testing a plain jane stock SCT data log to show it was working correctly, and walked me thru Live Wire to setup my own. Also mentioned on this forum and in SCT docs, backup, backup,, backup each version of your stuff, flash to stock, then do any updates to devices, setting and so on. i would do this on any device that is "tweaking" the brain in my car :)
