Whiskey11
Kill ALL the Cones!
Honestly, having tested all three settings on the BMR 35mm front bar, I wouldn't put it beyond the softest setting. Just enough bar to put the bias slightly into understeer territory, but not enough that you can't correct with throttle application. My co-driver and I have ran all three bar settings and the car just gets insanely pushy with the bar above the softest setting and requires a silly aggressive amount of throttle application to get the car to rotate at all...Likely exactly the same bar then.
I'd personally start on medium front bar, but everyone is really fond of the stiff front bar. I just noticed that it pushed more in big sweepers and didn't help much else. Maybe the MR shocks are the difference from everyone running normal shocks on the 15-17 GTs.
I guess the caveat to this is that I'm also running more than factory rear camber... at -2.2Âş out back, I think I'm the highest for rear camber in the FS S550 Mustang field. That might also explain my liking of the bar in the softest setting since the rear tires are sitting flatter to the pavement while cornering:
Still not as flat as I'd like, but tire wear is way more even across the back tires than the front tires...
