sai li fuel setup pump question
Bmaughan
Az
Ben
2015 procharged mustang gt
Quick question..anyone know if the sai li setup has both pumps running full time or is one on a hobbs?
Also i have 2 BAPs and i'm wondering if it would be worth running them with the setup for a little more headroom. Good idea? Not needed? I'm only looking for about 700-750 whp on E.
thanks!
Bmaughan
Bmaughan
Az
Ben
Also, i'm thinking about running a new fuel line. What size would be recommend at 750 whp on E85? -6AN or -8AN?
thanks for any advice!
fordfred
2016 Mustang GT...1970 Maverick...2011 F250
Not sure if the kit has changed since I got mine but mine does not have a Hobbs switch.
fuelforfire87
IL
2014 Shelby GT500
The Sai Li kit runs both pumps all the time. A BAP is not needed unless you are trying to make more than 800 wheel. I made 740 on E85 with mine on my 14 GT with a D1SC on the stock motor. I wouldn't waste money running a new fuel line as your stock line is 3/8" which is equivalent to -6AN. If you are ever looking to make more than 800 I would highly suggest just upgrading to a fore dual or triple pump system. That's what I will be doing since I have a built motor now.
ENPhoto
Hoonigan
Calgary, Alberta, Canada
www.ErikNymanPhotography.com
Erik
2016 Mustang Gt Premium Performance Pack
Bmaughan
Bmaughan
Az
Ben
Awesome... good info!
Yeah I already have the sai li kit...
Only reason I mentioned running a new fuel line is that I was considering putting a fuel filter inline (since the gt350 fuel pumps don’t have the same filters as the regular gt pumps)
and it just seemed like it would be easier to redo the whole line...
Perhaps I could just buy a few fittings to attach the filter at the end of the stock line in the engine bay... thoughts?
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
That’s the simple solution.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Terry Beefcake Reeves has Fore kits at great prices give him a call:
1 (855) 827-7223
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
Sai's dual pump kits run the pumps full time and aren't on a hobbs switch. You can add a hobbs switch if you like but I personally don't see any reason to. As far as running a fuel pump booster on them we typically don't recommend them in return style configurations as we recommend pumps to support the power level you intend on making from the beginning without the need of one. Can it be done? Yes. It's is a common practice? No.
Let us know if you have any other questions.
5ohh_kenny
Indianapolis, IN
2019 GTCS
WOW. Talk about reviving a dead thread.
Its my understanding the SAI Li kit is good for claimed 950wheel as is on E85 and turbo(s). Thats plenty for a vast majority of us.
Dominant1
Dr Frankenstang
from lethal's site:
System Power Ratings
850 WHP for Supercharged applications on E85 (900rwhp 2018+ GT's)
950 WHP for Turbo applications on E85
950 WHP for Race gas or Pump gas on Supercharged applications
1050 WHP for Turbo applications on Racegas or pump gas
Ratings based on using Injector Dynamics ID1050x injectors
5ohh_kenny
Indianapolis, IN
2019 GTCS
That’s what I meant by claimed. Would think at that ceiling the stock rails would
become a restrictions. If anything needs upgraded it’s the rails.
Dominant1
Dr Frankenstang
That’s what I meant by claiming. Would think at that ceiling the stock rails would
become a restriction. If anything needs to be upgraded it’s the rails.
The stock 15-17 rails are better then the 18-20 rails they will hold 900 hp
