S550 blend actuator door replacement info?
Warhead
South Carolina, USA
Warren
2015 Mustang Ecoboost Premium
So my 2015 EcoBoost appears to have an issue with the blend actuator door, where the driver side blows hotter and the passenger side blows colder. I can still adjust the temperature for each so it is performing some function, but the left is always much warmer vs the right.
Is anyone aware of a replacement help video or web page with pics to replace it?
I have searched and found complaints, but nobody showing how it's done on an S550.
Rod Schneider
Ball Ground, GA
Rod
2016 Mustang EcoBoost
I believe this may also be a symptom of a failing evaporator core.....
boosted4life
Fort Worth, Texas
2015 mustang gt
Yes that's a symptom that your low on refrigerant. We haven't had any issues with blend door actuators yet. More than likely your evap leaking.
Warhead
Warhead
South Carolina, USA
Warren
Yup, funny enough I had barely had a short trip when I posted this and then had to drive about 100 miles. By the end of that trip it was barely cool out of the right side towards the end.
I will approach it from this angle at this point.
Warhead
Warhead
South Carolina, USA
Warren
Dropped it at the dealer today, they just called to report it is the blend door and ordered the part to replace next week.
I will report back.
The Great Gazoo
Vancouver, Canada
2015 Mustang Silver GT/Auto
My A/C stopped working earlier this year. Brought to my lame dealer and they said the charge was low and recharged it and put in dye. Now my car windows are fogging up like crazy all the time. Seems like the recirc is on all the time so also maybe the blend door as well. Sounds like I got to bring it back again and drive a Focus for a couple of days again. :(
PTRP
Utah
I’ve been having the same problem on and off for the past eight months. I’ve been through three blend door actuator’s and they eventually replace the entire AC/heater box.
350sexZ
#655
corpus Christi, tx
ernest
2015 50yr ww 6spd -2014 explorer sport
Same symptoms I had. Until they put the new actuator in and said it turned out to be the a evap leaking.
