Datsun40146
Good day everyone,
I’ve been fighting steering play on my 05’ Mustang for a while. It’s not a S550, but the parts used were.
Throughout the steering range, not just on center the car has about an inch of total free play in the steering.
In an attempt to correct and replace worn components the follow measures were taken
The entire front and rear suspension is new GT500 or Ford Performance parts. Shocks, sways, FCA, etc etc,
Inner and outer tie rods are new as are the ball joints.
The steering column shaft was replaced in its entirety with a solid Borgenson unit from LMR. So it’s right and there is no bushing any longer. The bolts are in the correct direction.
I’ve had my partner move the steering wheel and the movement is 100% going into the rack. It’s just not moving the tie rods. I have no idea what’s left? I assume at this point it has the be the rack.
The OEM hydraulic rack and pump were removed and replaced with a used S550 EPS rack with a Wireeverything harness. Sport mode is selected all the time. The problem persists in all modes regardless.
To that end, there is a epoxy covered preload adjustment on the Mustang EPS rack. I checked it, adjusted it tighter and adjusted it back. (See the image if you want to know where that’s at) The wheel wouldn’t recenter on its own when it’s too tight. So, the preload I don’t thinks the issue. Even with it cranked down the play was still there.
I can’t believe this amount of slop is normal. Can anyone suggest anything else to try?
Steering slop video example
