andrewtac
Paxton has shipped, I’ve read the directions multiple times. I am about 99% sure I have it figured out, but I want to make sure on a few of the lines up front. I am going to run a stubby filter directly attached to the Paxton so I need to do things slightly different than the directions.
With the 2018+ Paxton kit the throttle body has a spacer with a barb for a vacuum port for the bypass valve, makes that easy. I have two more items that need vacuum, the switch for the FC3 fuel pump controller and a MAP reference for the fuel pressure regulator. For the FC3 switch I figured I could T off the vacuum line going to the bypass valve. For the fuel pressure regulator, I was thinking about using the port that hose #1 in the picture. The directions have you hook hose#1 up to the intake tube on the Paxton, well running the stubby filter I will not have an intake tube.
My question is with the aspirator, what does it do? The top hose (#3) goes from a vacuum source to the aspirator then to the power booster. The bottom hose (#1) the vacuum source is on the right and then it goes to the intake. I was thinking about pulling vacuum from right side of the aspirator on line #1, putting a T in the line, then capping off the left side of the aspirator. Or can I just put a barb in the right side and remove it from the aspirator completely and cap left and right sides on the bottom. I wasn’t sure is the aspirator is open inside and the brake booster shares vacuum from both inputs.
Line two I plan on venting to atmosphere, drivers side PCV. At some point I’ll either add a vented catch can to both sides or put breathers on.
