***RTR Rear Valance Diffuser Install Write-up***
Project Whitemare
GTFO Squad
Bay Area
www.instagram.com
Nick
2015 Mustang GT/PP
Click Below to Buy Exclusively from American Muscle:
RTR REAR VALANCE DIFFUSER
Disclaimer:
The RTR Valance Diffuser is made for use with a Premium Rear Bumper.
Tools Needed:
7mm Socket
1/4" Drive Ratchet
Panel Remover Tool
Dremel w/ Cutting Wheel
Optional: Offset Ratching Wrench
Optional: 7mm Nut Driver
Difficulty Level:
2 out of 12 Beers
Parts List:
(1) RTR Rear Valance Diffuser
Preparation:
Raise the rear end of the car and place it on jackstands.
Video:
>>>Coming Soon<<<​
Installation:
With the rear on jackstands, pull out the RTR Rear Valance Diffuser and inspect your parts.
You will need to remove the (2) bottom-most retaining clips in each of the rear wheel wells.
Once you remove these (2) clips, you'll be able to access (1) of the (3) 7mm screws that you will need to remove from the side of the rear valance where it meets the side of the bumper.
Although you can access the front-most screw from this orientation, I found it easiest to remove it from the underside with a nut driver.
Remove the remaining (2) 7mm screws from underneath the rear bumper coming from the side. This makes for a total of (3) 7mm screws to remove from the side of the rear bumper/valance. Repeat on the other side.
Pull the (2) retaining clips from the underside of the rear bumper where it meets the valance from the side. Repeat on the other side.
Move to the very rear of the vehicle and look for the (2) retaining clips on the outer edge of the stock rear valance, and the (2) 7mm screws in the middle of the stock rear valance. Remove these.
Once you have removed the (2) clips and (2) 7mm screws from the underside of the factory valance, you are ready to remove the (4) 7mm screws holding the reverse light housing into the stock valance.
Pull down on the valance from under the car to get a little more room and to see where the (4) screws are. Turn the light socket 90* counter clockwise and pull out of the way before removing the reverse light.
One more retaining clip to remove from the reverse light housing to free it from the bulb harness and then pull it free from the rear bumper and set it aside.
Here is where you'll want to crack open that first beer.
Time to remove the black valance from the factory bumper. All of the hardware has been removed and have just a few more body panel wedges to get past.
Work your way from the edge near the wheel well. Pulling firmly in a quick motion while supporting the bumper with your other hand, you'll see how the valance will remove.
Work your fingers up as far as they'll go as a wedge, and you'll have no trouble removing the valance from the bumper.
Tape up along the following line to be sure you don't bump the factory paint while cutting off the factory diffuser. Be sure to check for clearance before cutting. Use a dremel and make quick work of the rear valance.
Too late to turn back now!
Now you are home free! Crack open that second beer and get ready to enjoy your work!
With the stock valance removed from the car, and set down, begin to clip the RTR Rear Valance Diffuser into the OEM Valance.
Install the Reverse Light Housing into the RTR Rear Valance Diffuser using the (4) oem 7mm screws. Starting from the middle, place the complete diffuser unit into the rear bumper starting from the middle. You will feel/hear the "snap" as each of the clips slides into the OEM bumper. It shouldn't take much effort, but be sure each section is fully seated and secure.
Reinstall the remaining oem hardware (2) retaining clips from below the diffuser in the rear, (2) 7mm screws from below the reverse light in the rear. (3) 7mm screws on either side of the rear bumper where it meets the valance, (2) retaining clips on the bottom-most section of both rear wheel wells.
Place Reverse Light Bulb into socket and turn clockwise 90* until "locked" into place. Push reverse light harness retaining clip through the hole in the harness to secure it.
Sit back and enjoy!
jefc73
Detroit, michigan The Motor City
Jeff GTFO_0019
2017 GT350R
Nice work Nick. Will help when I install mine. How about some more pics brother. :thumbsup:
AMAlexLazarus
Malvern, PA
www.americanmuscle.com
Alex
'14 F150 EcoBoost/'08 Bullitt
Excellent write up Nick! This looks like a post I would've made.
Just like the man said, I'm gonna need some more pictures.
Alex
Khyber
it's a hard parked life
Lexington/Myrtle Beach, SC
Landon
2015 GT PP CO
theres f ton of pics in my thread yall :p if you need more pics of the valance. I got just about every angle possible...plus with the video
Good install in write up form though, project!
Project Whitemare
Project Whitemare
GTFO Squad
Bay Area
www.instagram.com
Nick
2015 Mustang GT/PP
Awesome write up brother, love the attention to detail and the difficulty level.. Looks amazing.
Appreciate it holmes! I try to stay very specific in the install write-ups. It's a bit overkill, but helps out with newcomers.
Sweet man! Glad it will be helpful to at least one person!
Many more pics to come!
Alex
They're coming! Promise! Had to squeeze the install in while taking care of my 3 year old. Had to take him out for ice cream for being such a good boy and helping with the install! :headbang:
Lost daylight yesterday, but I have something cooking!
Yup, ton of installed pics in your thread, and a great overview video. Sure was helpful in doing my install, but I wanted to put together something as thorough as possible...kinda needed an extra hand to pull and place the valance back into the bumper vs taking pics.
The video of my install is coming as well. Should be fairly detailed, and a great companion to use while using your video as well.
As previously mentioned, more pics to follow!!!
Blitz
San Diego
Tony
2015 Mustang GT/PP w/Perfomance
Great job Nick!!! I need to learn a thing or two from you!!
Stage_3
MA
2019 Roush Stage 3
Nice write up.
Good looks really good! Enjoy. :thumbsup:
Ultrakla$$ic
Whoflung Poo
Louisiana
Darren
2016 Mustang GT Ingot Silver Premium
Looks AMAZING on WHTMARE!!!!!!!!!!!!!!!:hail:
Project Whitemare
Project Whitemare
GTFO Squad
Bay Area
www.instagram.com
Nick
2015 Mustang GT/PP
Just uploaded a couple more pics of the installed setup.
Much higher quality pics will be uploaded tonight...
Teaser..
AMAlexLazarus
Malvern, PA
Alex
Teaser..
I think this is all I can say for now...
Project Whitemare
Project Whitemare
GTFO Squad
Bay Area
www.instagram.com
Nick
2015 Mustang GT/PP
Lastly to see how it'd look with Euro tails:
AMAlexLazarus
Malvern, PA
Alex
Looking incredible Nick!
Alex
