FMJ
Ok after waiting for my warranty to run out and planning this for a couple of years I finally took the plunge and did the oil cooler upgrade.
Just to set the tone I am generally pretty good with cars having stripped an Impreza back to the chassis and fully rebuilt it with plenty of customisation/restoration and I own most tools/have performed plenty of work on cars over the past 16 years.
With all that in mind I want to say that this job seems very simple on paper but it has some very awkward parts that require a lot of patience.
You can buy kits but I sourced the parts myself for about Ā£600 You could go cheaper, but I went with Teflon hose, setrab cooler and decent setrab fittings.
Also in the picture is the mocal thermostatic take off plate (the supplied silver colour fittings were removed and swapped for the better lower profile setrab ones). Some aluminium bar to make the brackets for the cooler. A setrab rubber dampened oil cooler bracket set. A samco U bend hose for the coolant lines with two sizes of JCS clamps as I didnāt know which size I would need. Some stainless bolts for the cooler brackets. A length of silicone hose to put over the stainless braid which would stop it rubbing against other things (stainless braid can cut through other materials due to vibration) I didnāt use the blue hose joiners in the end. Also some spare oil.
Firstly use a you tube video to take the front bumper off. You have to remove the radiator top panel/cover, and the engine under tray. I left the wheels on and had the car on ramps. You have to half undo the arch liners so wheels off may have been easier or if you are on stands you could turn the wheels to get more access but I managed like this. The hardest part is the little bumper mount screws (one on each side tucked up behind the arch liner) whoever designed these should be slapped. The best way to get at them was a short flex drive handle.
There is a lot of talk about bumper tabs breaking but certainly on this first time off mine popped off and on without issue. Just make sure you get the screws behind first and pull on the corners evenly as you pop the tabs away from the body work. Also make sure you have undone all the lighting wires and impact sensor wires before you try taking that bumper off. All the wires are easily accessed underneath once the under tray is removed.
