Return Fuel System question
Jeff_oddo
Colorado Springs, CO
Jeff
Mustang GT Premium
I'm curious as to if I will need to retune my car after I install a return style fuel system? When I say retune I mean start all over with datalogging for Lund to dial the tune back in. Thanks
GSLSE20B
Fair Oaks , Ca
16 SHADOW BLACK GTPP
Your return system will be mechanical controlled via a pressure regulator instead of voltage control via the ecu ?
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
Stock fuel system is a constant 58 PSI. Set the regulator at the same PSI. The tuner will have to turn off the Check Engine light for the fuel system.
Are you going to boost reference the fuel regulator?
Jeff_oddo
Jeff
Mustang GT Premium
beefcake
Bethel
2018 Ford Mustang
level 2 setup will be perfect.
with lund we do a base pressure at 55 and then use a boost reference to add pressure as boost increases.
the fore level 2 setup is a perfect fit.
when your ready let me know and we'll get you setup
beef
Jeff_oddo
Jeff
Mustang GT Premium
beef
Would I have to complete more datalogs kind of like when I first installed the supercharger dialing in the tune? Reason being is because I would be having it installed at a shop and want to be able to keep my remote tune. So if I just had to get an update from Lund and flash that tune that would be great.
beefcake
Bethel
2018 Ford Mustang
for sure
