Replace transmission’09, 4.0,5 speed
Jimz3stang
St Louis
Jim
2008 Fusion, 2009 Mustang coupe
Just picked this Stang, noisy throw out bearings and all gears but 4th. I’m having the trans swapped out with another, question is: when swapping trannys, we want to switch out the newer clutch and throw out onto new tranny, is the throw out bearing behind clutch ? Everything has to be removed, correct ? Thanks guys
Jimz3stang
Jimz3stang
St Louis
Jim
The throw out bearing and clutch kit was replaced 10 months ago now gears sounding real bad, should I have the existing clutch and bearing switched over or should I just buy new ? What part numbers or anything i should have on hand to replace right away ? Thanks.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Visiting the S197 forums may be the more ideal place to seek info.
Jimz3stang
Jimz3stang
St Louis
Jim
Looked for that, will look again.
Jimz3stang
Jimz3stang
St Louis
Jim
Thank you ! very helpful, happy cornering !
