6 Speed Auto Transmission
Sk7blue
Saeed7798
Saeed
2017 mustang gt
Hello,
I own a 2017 mustang gt 6 speed auto trans. Im posting this because I couldn’t find an answer to my questions. After i tuned my car a a very known place, my trans started shift weird. Especially 3-4. I went to so many tuners no one could help and told me that nothing is wrong with my trans. After all efforts, I went to the dealer ship and the car was diagnosed then they told me my trans needs a rebuilt however im pretty sure that the issue is not with the trans because this car is only 50k miles and has never been in a race. Can anyone help to address my issue. Thank you.
Jackson1320
California
Jaxson
2015 mustang gt
Hello,
What do you mean by weird?
vanquishvzla
Jacksonville - FL
2015 Mustang GT 50th anniversary
go back to stock tune and compare... if everything is smooth, the problem is the tune....
my canned sct x4 tune was GARBAGE... i hated how the transmission was shifting... specially down shifting... but after the PBD tune, now i love it...
Sk7blue
Saeed7798
Saeed
2017 mustang gt
I went back to stock but i have the same issue with the trans. I don't know is it because that Im full bolts on on a stock tune.
Rapid Red
Woodstock GA
Greg
How can a tune affect a manual trans ? Shifting & gear set is input from the driver ?
I'm lost
Emilbadal
Socal
Emil
2016 V6 Auto DIB
What’s the weird behavior you’re experiencing? Usually when you install a new tune, it takes 2-3 days for the ecu to learn how you drive and how it should modify its operations. Mine shifted super hard when I flashed my MPT tune to the point that I was concerned that something would break in the drivetrain, but after 3-4 days it calmed down and shifted properly. Oh btw, it seems that Drive and Sport have their own profiles and relearn period ,Afaik.
Sk7blue
Saeed7798
Saeed
2017 mustang gt
Thank you. I just updated my tune i will wait and see.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
If it's doing the same thing on the stock tune, your dealer is probably correct.
I learned to tune myself because everytime I bought a tune the trans would either flare the 3>4 shift or knock my fillings out on the 1>2. Usually both this even after giving it enough time to "learn"
The way I tune my trans now is to adjust the adaptive slip timer so the trans adjusts itself to a firm quick shift.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Op still has not defined “weird” .. 3&4 shifts are very different from 1&2. What are the shifts like when you use the paddles?
Dominant1
Dr Frankenstang
Not familiar with the term “flares” please elaborate...
K4fxd
NKY
The engine will rev up between the shift. Very hard on clutches.
Basically they release the off going clutch before the on going clutch can take the power. Another problem I have seen from tuners is they will hold the off going clutch too long. That acts like putting on the brakes between shifts.
