I already have my AC "on" when I last turned the car off. Next time I try to "remote" start it, it won't turn on the AC until I manually press the start button on the car when I sit down in the drivers' seat. "Auto" didn't work for me either.You should set it to auto if you want the AC to be always on.
Last setting meaning it will set to whatever was left off when you turn the car off. If you had it off before you turn the car off, it will not turn on.
I don't remember if the dash lights would turn on but you are saying when you get in the car after remote starting, the hvac is not blowing cold air until you press the start button?I already have my AC "on" when I last turned the car off. Next time I try to "remote" start it, it won't turn on the AC until I manually press the start button on the car when I sit down in the drivers' seat. "Auto" didn't work for me either.
Exactly. I've tried auto and "last setting" each a few times. Not sure what the deal is. Its a base model car, but I dont think that's the issue. It is in my dash screen, so it should work.I don't remember if the dash lights would turn on but you are saying when you get in the car after remote starting, the hvac is not blowing cold air until you press the start button?
Huh, I don't know how base model works because it does not have the "auto" mode that premium packages have.Exactly. I've tried auto and "last setting" each a few times. Not sure what the deal is. Its a base model car, but I dont think that's the issue. It is in my dash screen, so it should work.
True. Not sure why it even offers auto since I don't have auto climate control. Car is not stock, but "tuners" don't have access to this section of the software/hardware to my knowledge.Huh, I don't know how base model works because it does not have the "auto" mode that premium packages have.
Would be weird to even have that option in the dash to have "auto" if the climate control doesn't even have the function.
Is everything stock on your car?
I asked a friend of mine that has a base model with automatic, he said it would just turn on how you left it off. I find it strange that the dash would give you option to toggle between last setting or auto when you don't have automatic climate control.
