Removing the lower steering column shroud on a 2019?
barkingspud
NW burbs of Chicago
Mark
2019 Mustang GT Premuim
It appears that the upper and lower shroud are held together with plastic tabs moulded in to the upper shroud. Do I have to remove the steering wheel to get the entire shroud off or, is there a way to get the lower shroud without removing the steering wheel?
barkingspud
barkingspud
NW burbs of Chicago
Mark
OK. If you ever have to remove the Lower Shroud on the Steering Column, remove the Steering Wheel and use a trim removal tool pressing in on the joint between the upper and lower shroud and it will come apart without damage.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Does it pop open fairly easily?
Or is this a Grip of Death situation leading to broken plastic.
