Removing screw behind handle cover
jofivepointoh
Mustang GT PP
How did everyone remove the cover to the final bolt on door panel? What tools did you use?
NotMarc
Earth
22 Mach 1
Try a wobble extension on your ratchet. It's at a funny angle but using the wobble extension may help. That's the first thing I reached for so I don't know how it would be with a regular one.
Edit: sorry you meant the cover to the bolt, not the bolt itself. I used a mini pick from harbor freight. The set was on sale for I think $1.99. You could probably almost get away with a jumbo paper clip bent the right way.
Doug
Georgia
2015 Ecoboost
I used a pick with a 90 degree angle. There's a small hole at the top of panel you can slip it into and pull out.
Buhbuhj
NY
2015 EB Premium
I have a tiny bent screwdriver that I just put into the little slot up top and yanked on it.
