Removing Gas From Tank
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Does anyone know a quick and easy way to pump the gas out of the tank on the 2015? Is there anything that will prevent a hose from going down the filler neck to siphon it out? Is there a way to hook something the rail and let the car fuel pump pump it out? I want to get the 93 out so I can put e85 in for the track on Friday.
esacteksab
CO & KS
2015 Mustang GT
Since I'm assuming you have a tune in the car, your tuner should be able to send you a tune that runs the pump for an extended period of time. Disconnecting from the rail on the driver's side should suffice. They make kits http://www.jpcracing.com/jpc-2011-up-mustang-fuel-drain-kit/ but are $$ you can grab a fitting and hose and put one of these in-line
https://smile.amazon.com/dp/B00VU5X...TF8&colid=2TO08VZ59PCVQ&coliid=I3JH51ONPEW3MA
But you'll still need the tune to run the pump.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Thanks for the info. That is what I was looking for. Do you know if you can siphon it out as well?
esacteksab
CO & KS
2015 Mustang GT
I honestly don't, I'd imagine not, as most modern cars have a mechanism to prohibit bad people from stealing gas.
craigsix
overland park ks.
craig
2018 mustang gt
there is an episode on all girls garage where they run the gas out of a new mustang
RockStang
AA county MD
Joe
2016 GT Whippled
You getting ready to fill up on race fuel for tomorrow?
HoosierDaddy
Randy
There's a recent thread about a member trying to do that and doing a lot of damage to his car and wallet. Short version: hoses can check in but they can't check out and still don't reach the gas.
Need4Speed15
Parkland, FL
2015 Magnetic GT Auto
Cant you just pull the bottom of the rear seat and unplug the pump connector and hot wire the pump off the battery? Obviously disconnect the fuel rail and run a hose into a gas can first. Should work...
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I might try this. I am getting tired of trying to run all the gas out.
