Poppacapp
It's possible. I am getting 1.87s out of my 3.15 gear auto on 275 Invos.That 1.82 60ft does not scream factory tires.. but could be. Great times regardless for few mods.
Did not say impossible... simply not the norm. I cut 1.7Ă— all day long on goodyear F1s on my old lightning. Not impossible.... just not the normIt's possible. I am getting 1.87s out of my 3.15 gear auto on 275 Invos.
Still the same with higher power ignition coils now. Not doubling, but it is recommended you increase your gap on an NA car. I had Performance Distributors coils in my 13 and they recommended .52-.55 on an NA coyote to get the most out of the increased voltage. They may not be needed on these motors as plenty of people make big power on stock coils but I swear startup seemed more effortless and idle seemed smoother. But who knows.Anyone remember years back when the first MSD boxes came out. Everyone was pulling their plugs and doubling the recommended gaps.
The title of the thread gives all credit to spark plug gap but let's face it, MOST was weather plain and simple.Ok man your right. The car probably runs exactly the same if the gap is correct or not. Probably no science involved with that at all. Why do they even recommend gaps on spark plugs anyway if it has absolutely no effect on an engines performance???? Anyway to everyone reading this besides stoli. If you feel like your car is under performing. You should check the spark plugs. I DID and found them all to be incorrectly gapped from the factory by a large margin. After that was corrected. The idle smoothed right out and the car ran better! It's a very easy thing to do on these cars. It take all of 15 minutes! Or you can do nothing and live with it. Maybe stoli is right and the DA was 100% responsible for the increase in performance and had nothing to do with the changes in the gap I made. What if he's not right? His theory doesn't explain how my buddies car picked up 3MPH, 3 weeks ago after he received service? What do you have to lose even if it's only worth a tenth and a mile per hour? The point of this thread was to make people aware of a potential problem. Not quibble over DA. You can only try to arm people with information. Some people refuse to get off the tracks when you tell them a train is coming!:(
Do with the information as you will. I can see everyone want to argue. Im done with this thread. As I explained in the first post I got the idea from my friend who didn't benefit from weather and went the same amount faster after a simple plug change.
It would also throw a code if there were a misfire...Da does play a big part of hp,but also depending on how far a gap is off on a plug it could cause a misfire or not a complete burn which could affect Hp also.This is coming from someone with 30 years of drag racing and 27 years as a certified mechanic.That was a big difference in da but if one of them plugs was gapped open enough to cause a misfire u could easily see them kind of et gains or losses.Especially under wot conditions.
Yeah after enough of them. It takes more than one misfire event to throw a code. Misfires under WOT with modern engines are very unlikely if things aren't way off on the hardware side.It would also throw a code if there were a misfire...
And that reinforces my point. If the gaps were so wide as to cause a 3 tenths / 3mph difference in time, there would have to be very significant misfiring happening.Yeah after enough of them. It takes more than one misfire event to throw a code. Misfires under WOT with modern engines are very unlikely if things aren't way off on the hardware side.
Not arguing just trying to make sure that your misleading thread title doesn't give people the wrong idea.Do with the information as you will. I can see everyone want to argue. Im done with this thread. As I explained in the first post I got the idea from my friend who didn't benefit from weather and went the same amount faster after a simple plug change.
