dbranger94
So, I had a lady stop in my driveway when I got home this evening. She told me my tail light was out. I thought she was crazy, but sure enough my passenger taillight wasn't lighting up. I checked the turn and stop portions of the light and they worked fine. So, I thought I'd check the wiring connector and make sure it was ok and didn't have a loose wire or something. It was good. So, I pulled the light out to check the wires going into the lamp itself. Also good. I looked at the wiring diagram for the taillights and saw they both had the same connector and pinout, so I plugged the passenger light into the drivers side connector and it worked fine. According to the wiring diagram, the park LEDs get power from the BCM and the stop/turn LEDs get power from BCM-B. I also noticed that the section of the BCM that controls the park lamps had constant power. So, I disconnected the battery while I put the taillight back in the car. When I hooked everything back up the light worked like normal again.
So, if you have this happen to you, disconnect the battery. This will cycle power to the BCM and hopefully your light will work like normal again.
