Rear Brake awareness.
Gloucesternige
UK
'17 Mustang GT, GR Yaris, SWB Defender, Harley.
Hi everyone,
I have just stripped my rear calipers on my Gen2 GT to paint them. I was absolutely stunned to find corrosion in one of them!! This is not due to old brake fluid or moisture in the fluid as it is on the outer side of the seal, under the dust cover. There should be red grease in there, but there was none.
The reason I was so surprised is because the only time my car gets wet is when I wash it. it has never been driven on wet roads.
I have heard of issues with rear calipers seizing and locking on, I wonder if this is the cause? Next time you do/have your pads changed it would be a good idea to pull the seal off the piston front and check there's grease in there. You can't remove the seal totally, without unscrewing the piston, so don't pull it too hard, it wont come out.
Chappers
Sutton Coldfield, UK
Greg
Toyota Supra MkV - Tungsten Silver
Hi everyone,
thanks for the heads up and yes my car failed its MOT due to a siezed caliper not great at all!
Gloucesternige
Gloucesternige
UK
If you’re local I can have a look at it for you.
andyturbo2000
Lincolnshire
Andy
2016 Ecoboost Convertible
I’ve had both done because they both seized six months apart. It was the wrecked discs and pads each time that costed the most. Warranty covered though thank god
Chappers
Greg
This was nearly a year ago now and was in a pickle to get it sorted managed to source one and fit it myself, but thanks for the offer :like:
