Rear alignment after CB005 install?
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I know BMR recommends having the rear alignment checked after installing the CB005 kit since you have to unbolt the cradle. Are there points on the rear to make adjustments to the alignment? I am nervous that an alignment shop may make things worse. I have had bad experience in the past. I would love to hear what you guys experienced after installing the CB005.
Coaster
RallyNorthAmerica.com
Central Ohio
www.imprtcl.com
Brian
'15 Fastback GT Guard
Toe and camber are both adjustable from the factory. Sometime they have trouble figuring out the camber adjustment which is the inner mounting point of the upper arm.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Are either of those likely to get off from installing the CB05 kit?
Coaster
Central Ohio
www.imprtcl.com
Brian
It really depends on how out of alignment your cradle was from the factory.
If your car has never been aligned it's probably worth it anyhow, the factory isn't known for doing a good job to start with.
