Random Wire Plug Help - 2022 GT
grdrake
Atlanta, GA, United States
Glenn
Mustang GT
Need help identifying a random wire connector under hood of my 2022 GT Mustang. Checking engine fluids at front of car today and noticed a random wire plug near my washer fluid tank. Brown connector with two wire (Green Yellow Stripe and Blue). Just sitting there with no other missing connection point I can see. No fault lights on and everyting is working on the car as far as I can tell. Picture included and is front passenger side by radiator and windshield washer bottle. Appreciate the help.
Timbuck
Tim
2017 s550 6r80
That looks like a fan wire ?? Are your fans working ?
If it is , the white clip bracket will fit to the back of the fan just right of picture and then should plug into the main fan wires which is probably hanging down.
grdrake
grdrake
Glenn
Mustang GT
Thank you for the recommendation. I checked this morning, and the fan has the plugs fully attached above the fans on both sides, as you suggested. This plug has no home, from what I can see, and the fans work. No codes or lights are on. Still need help, like a wiring diagram to see what this could be.
Timbuck
Tim
2017 s550 6r80
It also could just be a none used connection. Ford uses similar harness on all cars and only use what’s needed for that optioned car. Normally the spare conector they just clip somewhere and are not used. Yours does have a Christmas tree clip on it , so maybe that’s why everything is fine and no warning lights etc.
