svtenthusiast
The new mustang is the same as the Escape with the "European" stalks on the steering column. The difference is on the Mustang you can turn off the rain sensing function in the dash menu and then it will enable normal intermittent function, unlike the Escape.The Ford rain sensing wiper system requires you to activate the wipers by moving the wiper stalk up. You can switch it between Off, Intermittent, and Continuous. For my '14 Escape, you flip the wiper stalk up one position to enable the wipers then you set the sensitivity with the rotating part (similar to how you'd do it in a regular wiper system). If you flip it up two spots (one past enabling them) it will wipe continuously.
